Xenon Headlamps?
Home Forums General Discussion Xenon Headlamps?
  • #233524
    MGLondonRoadste
    @mglondonroadste
    I’m looking at replacing the old sealed beams with a Xenon headlamp, which is promising 80% more light, brighter, whiter, and more efficient than standard halogen lamps.
    The bulb has High and Low beam, but I only have a single toggle switch for headlights.  It says this replaces all headlamps marked with 2D1 on the front of the lens.
    What do you all think?
    #245225
    Dan Rosa
    @dan-r
     Xenon lamps do put out a lot of light but do take a lot of power to do it if you charging system can handle it do it i do not do that much or type of speed to make that kind of change I just like  40mph not my age in speed   Dan,,, good luck
