Home › Forums › MGTD Kit Cars › VW Based Kits › Fiberfab Parts
- This topic has 7 replies, 6 voices, and was last updated 6 years, 6 months ago by
billnparts.
September 19, 2019 at 8:54 pm #306315
I recently post about an accident I had. End result is I need a new radiator grill shell. Does anyone have a source for one? Are they the same as the original TD grill shells? Can they be repaired and re-chromed?
Also need the fiberglass assembly that sits below the grill shell and between the fenders.
TIA
Al Greig
September 20, 2019 at 5:36 am #306316Sorry to have to see that. Hope everyone is ok.
There are distinct differences between the original TD grille and the ones provided by Fiberfab. The original units are actually easier to find, but then you have to modify the fenders and that front apron so it looks like it belongs.
I did find a place in VietNam that manufactures bumper kits although I haven’t used them yet.
Good luck.
"Drive Happy"September 20, 2019 at 10:00 am #306318I’ll add that not only are there differences between original TD and replica grill shells, but not all replica shells are the same and they are not interchangeable between replica manufacturers without modifications.
September 20, 2019 at 9:47 pm #306319Dang, Al. Sorry to see that.
May 12, 2020 at 7:16 pm #306715Does anyone know what modern car frame fits the dimensions of a mg td? (Width: 52in; Wheelbase: 96in)
I have an 1977 mg td kit and am looking to put the body on a newer car. Has anyone done this?
May 12, 2020 at 8:35 pm #306718We’re hijacking Al’s repair thread, but for a moment…
I believe you will not find a “modern car” to use as the basis for a TD replica. “Modern cars” do not have a frame. And unibody construction doesn’t lend itself well to the kit car world. You need a full frame to build the replica on.
As weak as it was compared to a “real” Mustang, the suspension and drive train from a Mustang II are fairly common components for TD replicas. Many kit manufacturers had custom frames built to accommodate Mustang II and Chevette drivetrains. With a light weight fiberglass body, the Mustang II V6 will get you more significant performance.
If that’s not enought, there are members here that have dropped V8’s into their front engine TD replicas.
Add fuel injection and electronic ignition to any of the above, and that’s about as close to “modern” as you are likely to get.
There were also kits that used MGB running gear, although they are typically difficult to find in the USA.
Now back to Al’s repair saga!
May 12, 2020 at 9:14 pm #306719I found a body shop that specializes in vintage Corvettes. It has been in shop since middle of January, all done except for grill shell. They had to fabricate a new front apron. The grill shell required removing chrome so it could be repaired and then re-chromed. Process is on hold because plating shop is shut down because of Covid 19.
May 13, 2020 at 5:55 am #306720FWIW…I have seen other TDr’s with that grille shell painted. It doesn’t look bad, just different .
"Drive Happy" -
