Home › Forums › General Discussion › A picture, finally
- This topic has 21 replies, 10 voices, and was last updated 14 years, 2 months ago by
john barry.
December 18, 2011 at 9:56 pm #233881
Hopefully, I’ve learned how to resize my original photo, but just in case this doesn’t work, I’m trying to post an image that made it into the 2012 calendar. This would be my Fiberfab with the Chevy 283 engine, bored out to .060 and a few other features.
December 19, 2011 at 4:50 am #248294mark,
Sweet !!!!!
December 19, 2011 at 7:09 am #248295Love the car and man those wheels! Way cool. Looks like traditional TD wheels. The MG emblem on the hubcaps and a TDReplica.com badge up front and your transformation will be complete!
"If one thing matters, everything matters" - from the book The ShackDecember 19, 2011 at 3:17 pm #248296Yeah, what hubcaps are those? I’m thinking those Nissan 4 bolt wheels will be good on any of the front engine cars–though a little too wide for us V-dubbers.
They’re very junkyard-findable. But I’d not seen those hub caps.
December 20, 2011 at 8:06 am #248297Lets pop that hood and see that 283.
Are the side panels cut out to fit the engine?
December 20, 2011 at 2:46 pm #248298When I first saw this car for sale, I thought it needs side panels, and I’m still leaning that way. The side visible to us in that photo doesn not seem to be blocked by any engine part.
However, on the drivers, side, the oil dip stick and some tubing (maybe brake line) stick out just past the wall line, so I’m not sure how to fit a panel around that.
For now, I’ll enjoy the “hot rod” look this monster of an engine gives me.
December 20, 2011 at 2:47 pm #248299Oh, for other photos, I’ll gladly post them, when it stops raining around here. I least I don’t have to shovel snow…
December 21, 2011 at 6:43 pm #248300I had considered a V-8 swap some years ago and determined that I would have to cut open the front of the side panels. I see that the front of your panels are intact. I’d love to see more photos.
"Drive Happy"December 30, 2011 at 2:56 am #248301interested in the wheels, Do you know what the source is?
Thanks
December 30, 2011 at 9:18 am #248302Sorry, I don’t know. I’ll try to take a close look at them to see if there is any information stamped on them.
December 30, 2011 at 4:24 pm #248303Correct me if I’m wrong, MGLondon, but I think I pulled one just like it from a late ’90s Nissan Altima last year. It’s 15 by 6 inches with a 4 x 114.3mm bolt pattern. AKA 4 x 4.5 inches, which is the same, I believe, as the MGA and MGB. (Also the Corvair, four-bolt Chevy Nova, early Mustang, etc. etc.)
See Nissan fitment guide here.
See universal guide here.
January 10, 2012 at 2:42 pm #248304I noticed “Nissan” on one of them last weekend. I’ll try to get a better look on Saturday morning. It’s too dark by the time I get home this time of year.
January 10, 2012 at 6:52 pm #248305Will a regular MG TD hub cab from Moss fit on a V W bug wheel?
January 10, 2012 at 7:28 pm #248306Sorta kinda. You have to put studs in the wheel, and the MG cap sits on top of the ridge that the VW cap fits over, leaving the four “ears” on the wheel exposed. Looks sort of funky, but it’s been done.
I don’t think it looks better than the plain VW cap with the MG emblems.
edsnova40918.8257407407
January 10, 2012 at 7:42 pm #248307John, The short answer is no. I saw somewhere that you can weld bolts to the VW wheels which if positioned correctly,will hold the MG hubcap in place. The center part of the VW wheel will still cause the hubcap to stick out farther than it does on the MG wheel as the cap sits on top of the bumps on the VW wheel instead of fitting over them. There is a company called Proto Research in Canada,Ibelieve, that sells completed TD replicas and they use this method.You can google their website and see for your self.
I’ve been meaning to ask, are those Porsche emblems on your hubcaps?
January 10, 2012 at 11:37 pm #248308Prototype Research is the Canadian firm that still builds a TD replica.
The link in Ed’s post above is to their web site
January 11, 2012 at 10:14 am #248309Thx paul,larry,and ed. I have porche medallion on my hub caps now
and are showing signs of rust(taiwan) appreciate the info help
January 12, 2012 at 2:42 pm #248310Hub cap medallion question. How do the MG medallions (moss motors) attach to the hub cap….does it have a stud?
thxzzz
January 12, 2012 at 7:58 pm #248311John, You got it right. There is a stud on the medallion that fits thru a hole in the hubcap. The stud has a hole thru it cross ways near the end. A cotter key goes thru the hole and flat washers, possibly plastic or felt ,take up the extra length of the stud to insure a snug fit.
January 12, 2012 at 8:02 pm #248312thx larry, thanks so much !!
January 13, 2012 at 3:20 pm #248313John,
Larry is right about the studs on the medallions. I used Mcmaster carr part# 9716K52 which is a spring type washer that will hold tension on the medallion and keep the rattle out. The medallions from Moss Motors look very nice. It should be an easy change out to put them on your car.
January 14, 2012 at 1:59 am #248314MIke
Good one – thanks so much ..I appreciate the help..
