Home › Forums › General Discussion › Classic Roadsters Duchess Wind Wings
- This topic has 9 replies, 6 voices, and was last updated 8 years, 12 months ago by
davearoy.
March 30, 2017 at 12:54 am #303330
After searching for 8 years, I finally made the unique Wind Wing mounts for my Duchess. The chrome plexiglass bracket piece came from a Cobra web site “FinishlineAccessories.com” for $80, including all hardware, OUCH! Hind sight, I should of made them out of 3/4 inch channel Aluminum, like I did the 1/2 inch channel wind shield mounting bracket, which I purchased from Home Depot for $5.99. Pictures are below in the following post, which are also on my profile page. It took me 2 days to make 4 hinges, they are a little rough, but I am trying to get ready for a car show this weekend here in Florida. I had a sign company make new plexiglass Wings for $80, using my old Wings as a template. This has been a pricy adventure, but what else has a retired guy to do besides drink beer and do car shows, (big grin).
Dave
This topic was modified 9 years ago by
davearoy. Reason: Correct spelling error
Dave
Lakeland, Florida, where we drive Topless every dayMarch 30, 2017 at 2:59 am #303336https://tdreplica.com/members/davearoy/media/464/
Sorry Paul, I am trying to post a picture of my manufactured Wind Wing for my Classic Roadster Duchess. I am using my IPad and posting pics already uploaded to my TDr sites profile page. Can you maybe make my pics live? Thanks I appreciate you brother!
Dave
Dave
Lakeland, Florida, where we drive Topless every dayMarch 30, 2017 at 6:02 pm #303352Apple products do not like this site. For photos use your desktop.
"Drive Happy"March 30, 2017 at 6:36 pm #303353That’s some fine work if I do say so! Mighty fine indeed!!! My wind wing hinges are also from Classic Roadsters Ltd. and I like yours better!!! The previous owner replaced nuts and bolts with whatever was around the garage and the plexiglass is amber…I’ll be replacing mine before long…
March 30, 2017 at 7:37 pm #303355Nice job, Dave! Like I always say, “fabrication is FUN!” (Ok, I’ve never said this).
March 30, 2017 at 11:08 pm #303363Thanks guys your comments are very flattering and encouraging to make my next set better. I can not believe that I did not think of doing this before. I gave the fabricated brackets the 65 + test today on the interstate, and they held up with no problems what so ever. My next set will have just a little taller side walls to increase the strength of the windshield side bracket mount.
“Neccesity is the mother of invention”
Regards………. Dave
Dave
Lakeland, Florida, where we drive Topless every dayApril 3, 2017 at 9:22 pm #303388
April 3, 2017 at 9:25 pm #303389
April 4, 2017 at 8:10 am #303392
Dave
Can see that you are starting from the aluminum channel on left and then fabbed the half of the hinge in second image. The ears of the fabbed piece appear to be of a higher profile than what you started with. Die you weld the aluminum ears or is it just optics? Assume the third image was the template of what you gabbing, correct. In fourth image you are showing chrome left half and the fabbed right joined with SS or chrome bolt and what looks like a nylon bushing that when tightened together provide the friction tension that keeps the hinge parts from closing. Correct? Would adding star washers between the bushing and the inside ears of the hinge help with retaining the tension without damaging hinge ears? Looks like a practical solution for anyone who want to add adjustable wings. The wings on my FF are fixed so can not be adjustedDavid B Dixon
SabineApril 4, 2017 at 11:02 am #303395Hey David, I appreciate your astute observations. I used 1/2 ” channel Aluminum stock, the ears are 1/2″ so you are just seeing optics from the angle. Yes the 3rd image was the original Duchess part that I used as a temple. I looked for 8 years to find an exact replica, before it occurred to me to just make a replica out of Aluminum channel stock. I left a wall of approximently 1/8″ high to give the bracket some strength. I also heated this Aluminum bracket, and bent it ever so little, to match the original, and the slight curve of the windshield frame. You are correct, the plastic bushing is to prevent any “crushing” caused by tightening of the bolt and nut. I did use a star washer between the nut and the steel chrome u shaped bracket that is mounted to the Plexiglass Wind Wing. This gives plenty of tightening power so the hinge does not move while driving. This system works so well, that I find I have to loosen the tension on the hinge during car shows as if someone bumps into the Wind Wing, or if pranksters purposely turn my mirrors and the Wind Wings, they will move freely, and not crack the Plexiglass. I hope that I have answered your questions. Thanks for asking.
Regards
Dave
Dave
Lakeland, Florida, where we drive Topless every day -
