Clutch Cable
Home › Forums › MGTD Kit Cars › VW Based Kits › Clutch Cable
  • #234633
    Richard Shear
    @gbidick
    Broke the Clutch Cable on my Roadster. Took the broken cable out and it looks like a VW Beetle cable that has to be cut and spliced to shorten the cable. New cable about 89 inch’s and cable needed about 69 inch’s. 2 U-clamps used to splice cable together after shortening the cable. Not as bad a job as I thought. They don’t make cable that last anymore, only lasted 27 year’s.
    #255517
    newkitman
    @newkitman
    That’s the standard way for attaching the VW clutch cable. You you 3-4 inches back from the threaded part and secure the two halves (after installing) with two cable clamps. I recommend changing the cable clamps as well. They only cost a couple of dollars and you have all new hardware working under there. Should last another 27 years!
    #255518
    Richard Shear
    @gbidick
    Thanks for the suggestion Allen Good idea.
    #255519
    You don’t need to cut the cable either. Mine’s looped and clamped.
    #255520
    Richard Shear
    @gbidick
    Job done and now I can get my inspection. Hooking the cable back on the clutch pedal asm. was a pain, not much room.
    #255521
    Dale Schumacher
    @schu
    Dick,
    Sure you need a inspection? In VA w/ a vintage tag it is not required – I did not know that till the last minute and was informed.
    Dale
    #255522
    Richard Shear
    @gbidick
    NY requires a safety inspection every year.
