Home › Forums › MGTD Kit Cars › VW Based Kits › convertible top keeps coming off in front
- This topic has 3 replies, 4 voices, and was last updated 3 years, 4 months ago by
billnparts.
February 21, 2022 at 8:28 pm #307967
I removed the top recently and when I put it back on, I must have changed something. Now the front keeps coming out of the groove while driving. I’m assuming that something needs adjusted (tightened?) but have tried a few things and nothing works. Any ideas?
March 1, 2022 at 9:45 pm #307981Bud,
Early Duchesses had an aluminum bar slid into the pocket at the leading edge of the roof. I never had an issue with that.
At some point, I had to replace the roof. The replacement from Classic Roadsters had a flexible “plastic” bar in the pocket. The aluminum bar from my old roof would not fit. And I started having the problem of the roof pulling away from the windshield frame.
I added snaps at the top, outer corners of the roof (on the little flaps that tuck into the sides of the windshield frame). That pretty much solved the problem. But to be honest, I was never 100% confident in it.
I think the real solution would be to have a machine shop mill down a flat aluminum bar to fit into that pocket.
November 17, 2022 at 2:55 pm #308303I picked up a 1/8″ x 1″ x 48″ aluminum strip at Ace (True-Value) Hardware for less than 10 bucks. I cut it to fit the width of the channel, polished the strip on my buffer, and then used rivets to fasten the forward lip of the top to the strip. Be sure to leave enough room to get the bar into channel when you attach the top lip.
I haven’t finished the car yet so I can’t promise any success, but it will certainly beat the #%* out of trying to stuff that saggy lip into the channel with no support.
Jeff Troy
759 New Holland Ave.
Lancaster PA 17602
717-917-3670
jefftroy@aol.com
www.bandmix.com/jefftroyNovember 20, 2022 at 9:08 am #308305I could never keep my top in that groove. It’s unnerving when it lets loose at speed. I placed a row of snaps under the top of the frame. No problems since.
"Drive Happy" -
