Duchess Owners
Home Forums MGTD Kit Cars VW Based Kits Duchess Owners
  • #234561
    Rick
    @rockyx
    Has anyone figured out a good way to secure the engine cover when doing simple work like adding oil or changing plugs?
    A strap?  Rod? ??
    Paul?
    #254893
    Royal
    @royal
    Works for me.
    #254894
    Rick
    @rockyx
    Roy,  thanks for the pics and details but the Duchess engine cover opens the other way.  It is hinged on the bottom not the top.
    So I need something to keep it from over extending. I could put a stick on the ground underneath it but that just doesn’t see very stable.
    #254895
    Yes.
    Classic Roadsters assembly manual says to just let the spare tire rest on the bumper. That works, but leaves a mark across the sidewall of tehspare.
    For years I just used a couple straightened coat hangars. But I wanted something a little nicer in case I wanted to leave the engien cpover open at a show.
    I bought some chain, cut it to the necessary length for each side and attached a couple small caribiner style clips to one end of each.
    The links on the chain slip over the hooks on the engine cover. The caribiners clip through the holes on the latches that are attached to the body.
    PMOSSBERG2013-03-07 14:56:32
