Fuel Line
Home › Forums › MGTD Kit Cars › VW Based Kits › Fuel Line
  • #233631
    Tom Colello
    @gunfighter
    How is the fuel line run from the tank to the engine on the cars with VW type gas tanks like the Fiberfab cars?
    #246013
    A steel fuel line that runs through the center tunnel.
    At the front, It emerges from the top of the tunnel, underneath where the fuel tank would have been in the stock Beetle.
    Flexible fuel hose connects the line to the tank at the front and to the fuel pump on the VW engine.
    #246014
    Tom Colello
    @gunfighter
    Thanks Paul. I was just wondering. I know the tank in the MG sits back further than the stock location in a beetle and wondered if a new line was run up out of the tunnel or there was a flex like running from the tank to the original fuel line in the tunnel up front.
    #246015
    Marc Lipsius
    @mrlmd
    Whoever built my car ran a length of fuel line from the tank then to a copper line run under the left floorboard along the pan and up into the engine compartment, then another fuel line to the filter and fuel pump. I may blow out the old line in the center tunnel to see if it is clean and unobstructed because I think my present line is a little too exposed.
    #246016
    Peter C. King
    @bdriver
    Even hard copper is a relatively soft metal. The pan is steel. It will rub a hole in copper over time. That’s why fuel line is either hard steel or braided stainless steel. The braided line carries a warning about abrasion. Think about replacing what you have with steel. The bender isn’t expensive. Harbor Freight carries it. Line is available by the roll from Eastwood. Better safe than very sorry. VW engine fires tend to ignight the magnesium in the crankcase. They aren’t pretty.
