Home › Forums › MGTD Kit Cars › My Project › Gone and Done It
- This topic has 215 replies, 23 voices, and was last updated 10 years, 9 months ago by
billnparts.
April 8, 2013 at 8:19 pm #253980
First coat after sitting all night before sanding. It leveled pretty well.
Wet sanded everything this evening. After a few more coats, this just might work. I had reservations.
"Drive Happy"April 8, 2013 at 8:53 pm #253981And I stayed at the Holiday Inn Express.
The only marine topcoats that I am familiar with are Awlgrip and Imron. What are you using?April 8, 2013 at 8:58 pm #253982Petit…picture of can in first post of this thread.
"Drive Happy"April 11, 2013 at 9:04 pm #253983Second coat applied tonight. Looking much better I’m starting to think she’s going to look pretty good
"Drive Happy"April 13, 2013 at 6:46 pm #253984It took very little effort to sand the second coat smooth. I had applied the paint with a cheap foam roller from Harbor Freight. This resulted in a lot of surface air bubbles which I eliminated with a soft stroke with a clean foam brush.
Remember this panel from a previous post?
Current condition
Third coat tomorrow.
"Drive Happy"April 13, 2013 at 8:35 pm #253985Wow. I gotta up my game.
April 13, 2013 at 8:51 pm #253986Bill, sure looks great in the pics.
April 14, 2013 at 9:04 am #253987Bill, Very cool – looking forward to seeing the results – you may have just turned me into a painter for my Speedster project.
April 14, 2013 at 6:44 pm #253988I ran out of paint on the third coat. I had just enough to coat all the panels. With only a month to go, I think we’ll stop there and put it together for the run to Carlisle. We still have work to do on the fenders and running boards. They will definitely not be painted so for those who liked the “patina” you can revel in it’s beauty. We’ll wait to polish and clear the main body until we’re home from Carlisle. There’s always 2014. And to think this started with a gas cap.
"Drive Happy"April 14, 2013 at 9:36 pm #253989Go man, go!
April 15, 2013 at 8:28 pm #253990Her ass now matches her main body…
"Drive Happy"April 21, 2013 at 4:26 pm #253991A busy day…we’re showing some progress. both my wife and my son said that “…its looking like a car again…
I had never ran welting between the front side panels and the main body tub. I tried it, I like it. I think it makes for a finished look. The original build instructions never called for it. At this point I only have the hood portion of the welting taped until the hood is in place. Where that closes will determine where the welting is finally placed.
Those of you that have welting there, how do you have it fastened? I was considering small flat head screws. Any better suggestions?Bill Ascheman
"Drive Happy"April 21, 2013 at 5:21 pm #253992Anonymous
InactiveI don’t have welting there but a glue might work.
April 21, 2013 at 5:21 pm #253993On my Duchess, the welting that goes across the cowl is glued (3M’s Fastack), wraps around under the cowl and is sandwiched between the cowl and the body parts underneath it.
It’s stayed in place for 31 years!
PMOSSBERG2013-04-21 17:23:04
April 21, 2013 at 8:50 pm #253994Big rivets.
April 21, 2013 at 9:15 pm #253995Most of mine is pop riveted.
April 21, 2013 at 11:13 pm #253996I would not drill all those rivet holes over your feet and over all the dash wiring. And the rivets in place would sort of undo the purpose, which is to cover another area of fiberglass to fiberglass contact.
It seems Classic Roadsters is one of the few that called for welting around that area. Their solution works. And has for 32 years on at least one example.
(see page 33 of the assembly manual, which is page 11 in Part 2 of the CR manuals on our download manuals page).Why not follow their lead?
Just sayin…
PMOSSBERG2013-04-21 23:14:04
April 21, 2013 at 11:26 pm #253997In my 55 all steel pickup, the fender welt was to keep the muddy water from coming through the cracks between fender and body. I didn’t particularly like the hassle of putting them in place nor the finished look. You mention fiberglass to fiberglass contact. What does this cause? Squeaks, rubbing, powder, paint damage? Or is it just cosmetic?
April 22, 2013 at 7:37 am #253998Squeaks, grinds fiberglass and/or paint away. The is especially true in places like the hood-to-cowl area, since the hood is on kinda “loose” with hinges and a latch or two. At the fender-to-body joint it’s probably fine, since they’re joined tight.
The welting does look correct, though, as it matches what’s on TDs. Whether it looks good or not is a matter of personal taste.
April 22, 2013 at 10:59 am #253999didnt many of the older production cars vintage ie 30’s 40’s , 50’setc have welting btween body and fender parts?
I thought i remembeerd welting on my uncles 51 chevy deluxe
jebarry2013-04-22 12:07:02April 22, 2013 at 12:16 pm #254000My ’40 Ford has welting between body and fender parts and we had a ’51 Chevy and as I recall it had welting at least on the rear fenders.
Don Loveless
Ford Pinto Fiberfab
Rochester, MIApril 23, 2013 at 7:52 pm #254001Man, did you ever have one of those days when everything you do turns to sh*t?
I had to call it quits tonight. As everything escalated, I just became angry and nothing was accomplished. My garage was disorganized when I decided to rip the car apart and nothing has gotten any better with the car strewn all over the garage. I couldn’t seem to find anything tonight and it drove me nuts.At least I managed to some glass work done on the fenders and running boards before venturing out to the garage. Hope tomorrow goes better.Bill Ascheman
"Drive Happy"April 23, 2013 at 8:13 pm #254002Been having that kinda day myself with mounting the grill. Nothing went right. So….you did the right thing. Which was to back off and rest for the night. Tomorrow everything will fall into place. Well if not everything it’ll at least go better. Hang in there Bill and you “get er done!”
"If one thing matters, everything matters" - from the book The ShackApril 23, 2013 at 8:19 pm #254003Happened to me yesterday. Got up early, as is my habit, dressed in the dark so as not to wake Julie. I should have known what kind of day it was going to be when I put my jockey shorts on backwards. ………should have gone back to bed. The good news is: today was pretty good.
April 23, 2013 at 9:07 pm #254004Ah yes. Many days like that. I’m still working on the skill of “leaving it be.” That is the key thing.
Hoping to get back to work on the car in the coming week. Been doing the second tier of the terrace & it’s almost done. Got the caps glued on tonight; Saturday morning I’ll have a couple guys here to help dig and fill ‘er up with enriched soil. Then it’s down to cleanup and grass seed.
This wall is 50 feet long and 33 inches high.
One more tier to go….
