Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › Hood length on Ford CMC
- This topic has 22 replies, 13 voices, and was last updated 10 years, 12 months ago by
Montie Henderson.
March 31, 2015 at 10:00 am #235662
I am assembling a CMC ford pinto kit. The PO trimmed the hood and it is way out of square. Could someone measure the length of their hood right down the center and let me know what the dimension is? I am just wondering if I have enough material to straighten it out properly without making it too short.
March 31, 2015 at 12:39 pm #263920Hi wings….
This is going to be a fun thread to watch.Your question is perfectly logical…but….If six owners respond, I’m willing to bet you will receive six slightly different answers. Remember, for the most part, these are hand built cars, even the “factory builds.”And the only measurement that will really matter is the one on your car.Hopefully you haven’t and won’t touch the hood until you have the body assembled and the grill and cowl are in place. It’s only then that you will know for sure about your hood fitment.If your body panels bolt together, there will be some room for minor tweaking if the hood fit isn’t right. I would keep things a bit loose until everything is in place.PMOSSBERG2015-03-31 12:39:54
March 31, 2015 at 12:47 pm #263921I figure the number will be all over the place, but at least I’ll have a rough idea for starting point.
March 31, 2015 at 1:04 pm #263922Let’s see how many variations are out there. I’ll measure mine when I get home from work.
"Drive Happy"April 1, 2015 at 9:02 am #263923Mine is a Ford kit and I’m quite sure it’s a Fiberfab.
The length of the hood measures 44 7/16″ center, 44 1/4″ right edge and 44 1/8″along the left edge.To get a good fit I had to leave the remains of a crude scribe line 1/4″ at the front edge of the hood.I recommend you always measure and test fit each panel before making a cut. It will take a lot more time to add back later.Don Loveless
Ford Pinto Fiberfab
Rochester, MIApril 1, 2015 at 9:09 am #263924My ’82 Fiberfab, unmolested hood is 47 inches, I may not use it.
Mel
April 1, 2015 at 9:50 am #263925Like I said mine was trimmed by the PO and is at 45.5 and way out of square, so it looks like I have plenty left to trim once I get the grill mounted to the side panels
April 1, 2015 at 10:00 am #263926Just wondering if the front engine kits have hood lengths different than a VW based kit. Seems the hood would be the same regardless. I’ll measure my VW based Fiberfab hood just for grinzos.
"If one thing matters, everything matters" - from the book The ShackApril 1, 2015 at 11:03 am #263927*****Daytona VW*****
******* 42-7/8″******
April 1, 2015 at 4:58 pm #263928I’m also building a CMC Ford Pinto kit, but the fiberglass pieces are about 45 miles away in the shop on my small farm. I’ll measure it when I go over to check on “money pit/Camp house” on Friday 4/3/15. I’m glad to add another “random number” into the hood lottery.
JohnnyB
April 1, 2015 at 5:58 pm #263929***** CMC/Fiberfab VW-based *****
44-3/8 Right
44-1/2 Center
44-3/8 LeftAllen Caron
"If one thing matters, everything matters" - from the book The ShackApril 1, 2015 at 7:20 pm #263930Finally…
44-1/2″
Mine has also been trimmed due to front end wreck.Bill Ascheman
"Drive Happy"April 1, 2015 at 8:57 pm #263931I am glad this topic came up. The PO who had mine trimmed the hood and side panels wrong and uneven. It took three months of head scratching and trial fitting to get both left and right sides even and level. Almost my break point. The fender heights are within 1/2 inch of each other. The hood took at least 5 or 6 trimmings to match up to the grill and cowl sides evenly. I started with a 47 inch hood and ended up with a 45 inch hood, which meant trimming the side panels to match. Cut-test fit -cut again- etc.
April 1, 2015 at 9:15 pm #263932This is good stuff. Like I wrote earlier, the beauty of “hand built.”
I’m not home to measure my hood. I will this weekend. But I predict that one side of the hood is a quarter inch or so shorter than the other side. Why? Because the entire car is just a wee bit out of kilter. You’d never know it from curbside. But the measuring tape never lies.I blame the builder. Some smart a** 23 year old kid who thought he could build a giant model car out of a kit.Oh.Wait.What?Yeah, right! That 23 year old wise guy was me!Paul Mossberg
April 1, 2015 at 9:34 pm #263933Like snowflakes, these are.
April 1, 2015 at 9:40 pm #263934BCW Chevette = 46″ center both top hoods, 45 3/4″ right side, 45 5/8 left side
Chevy 2.8 V6, 5 speedApril 1, 2015 at 10:25 pm #263935BCW VW = 46″ also, hood center. It is my understanding (and the manual says) that the parts in these kits were pre-assembled or mfg’d to closer tolerances and so did not require stuff like “hood trimming.”
The BCW cars were also some 3 inches longer overall than real TDs, so an inch or two extra in the hood is no surprise.edsnova2015-04-01 22:26:59
April 2, 2015 at 1:12 pm #263936Like snowflakes, these are.
Thanks, Yoda.
"Drive Happy"April 3, 2015 at 1:23 pm #263937Another point of reference is the the Hood “Strip”, available from MG Magic Inc., S/S Finished ends 44 1/4″ with fasteners. My kit did’t include a hood strip and i’ve been thinking about adding one. At 44 1/4″ it should fit my 44 7/16″ hood.
Don Loveless
Ford Pinto Fiberfab
Rochester, MIApril 3, 2015 at 2:49 pm #263938Don, I thought of doing that also since my Daytona has no chrome or ss hood strip either. But, I have a raised section in the fiberglass which would be directly under the strip. Decided against it.
I believe that the fiberglass on hoods of cars with the strip are flat. (no raised section or bump)
April 3, 2015 at 7:26 pm #263939Roy, I guess my options are still open. My hood (Fiberfab) is flat, no raised section or bump. 🙂
Don Loveless
Ford Pinto Fiberfab
Rochester, MIApril 5, 2015 at 2:00 am #263940Classic motor’s Duchess
Chevette
44.5″ center 45″ both sides.
Flat hood with center strip.No trees were injured in the making of this message, but some electrons were inconvenienced.
April 5, 2015 at 9:31 am #263941CMC factory built; 44 3/4 down center 44 1/2 each side
