Hood Seal
Home › Forums › General Discussion › Hood Seal
  • #235119
    newkitman
    @newkitman
    What type of seal is used on the front and rear of the hood?
    #259913
    Baby harp?
    #259914
    KentT
    @kentt
    edsnova wrote:
    Baby harp?
    He needs rename his build “Orca” and perhaps change the color scheme… 😛
    Allen, I suggest you trial fit the hood over the scuttle and the grille surround, then see how much space you have to work with.  You can get universal “O-shaped” seals that are hollow in the center, in a variety of thicknesses.
    On my old FF kit, I couldn’t use anything thicker than a piece of welting on the grille shell, but I used 1/4″ solid foam + welting on the scuttle, as I recall.
    #259915
    newkitman
    @newkitman
    Baby Harp! Good one Ed.  😛  PETA wouldn’t allow it though.
    I have some black welting and white welting. The white welding is on the scuttle but its a bit thin. I think the white welting will work on the front. I’ll have to check it out tomorrow. Perhaps add a second piece of welting on the scuttle only with the bead facing forward.
    #259916
    Mike Schumacher
    @juneybug
    mg magic has the rear hood seal for $30
    #259917
    I have welting on the body cowl and radiator grill shell.
    And a thin universal rubber seal on the undersides of the hood.
