Home › Forums › General Discussion › how much gas do i have
- This topic has 10 replies, 6 voices, and was last updated 15 years, 8 months ago by
June 25, 2010 at 10:15 pm #233039
A few days ago my fuel gage went to empty and stayed there
i topped the tank empty still i took the back off to get to the sending unite removed the sending unite the float was full of gas i tyred to solder the hole but there were many as i wire brushed it more came up so I went to advance auto no luck at all !!!! the counter persons /more than one/ had no idea what i had
NAPA could get one next day OK good got it
now the good stuff my gauge always shook
now what to do I took a spring that comes in a toilet paper holder the smaller spring i cut a coil off of it and put between pivot and the open side just enuff to take the play out now i have no more flutter on my fuel hand
quick no cost fix …but $12.00 for the float. ……….. DanJune 25, 2010 at 10:27 pm #241687Improvisation works…for comedy, music and fixing cars!
I am familiar with the duct tape & bobby pin approach to automotive repair. And once in the middle of Mexico, I helped a cab driver repair the throttle linkage on a VW microbus with bailing wire (true story).
But this is the first official toilet paper roll fix-it story I’ve ever heard. Good thinking Dan.
June 26, 2010 at 11:58 am #241688Dan,
I Love it!!!
If you’ve ever fixed your car with a toilet paper holder,.. you might be a genius!
Ringo
June 26, 2010 at 12:25 pm #241689I’ll be lookin to do the same when I go thru my gas tank. My guage never reads higher than 3/4. New float for sure-and maybe a TP spring as well.
Of couse, having a working gas guage does make the car less “authentic.”
June 26, 2010 at 9:57 pm #241690ed ,,,,I think your float would be good ..if the hand only goes to 3/4 on a full tank and it works OK lower than that i would try to adjust it making sure the slider at bottom of the tank and the float arm at the bottom of travel showes empty on mine about 1.5 inches from the bottom of the slide adjuster give it a try ,,,the gauge is only an OHM meter the float arm rubbs on a coil of resister wire ..As for the spring to hold the float arm from jumping on and off the the resister coil it works good on mine
GOOD LUCK ………DanJune 27, 2010 at 8:25 pm #241691Thanks, Dan. I’ll definitely examine it before I buy parts. Hope you’re right.
June 28, 2010 at 12:18 pm #241692OK…instead of “My ride kicks butt”…it’s “My ride wipes butt”?
I couldn’t resist
June 28, 2010 at 6:12 pm #241693I guess mine is more authentic, gauge hasn’t worked since I bought it. Tried to get to it to check it out, it didn’t look possiable without removing the whole back of the car. Was on the list last winter but did the engine dress up instead. Maybe next winters project. For now, go about 100 miles and fill her up.
June 28, 2010 at 10:36 pm #241694I ran using the odometer as my gas gauge for 27 years.
The stock VW sending unit in my Duchess’ gas tank reached only half way into the tank. So “empty” meant half full!
This spring, I finally found a universal gauge with the correct resistance for the VW. Now I actually know how much gas I have!
Of course then the engine blew. (:
June 29, 2010 at 10:10 am #241695Paul ,,,can you fix it with a wire and a spring
I got extra
DanJune 29, 2010 at 9:10 pm #241696Talked with the owner of one of the “best damn garages” in NJ today.
From my description of events, he thinks, the pushrod was working it’s way off the rocker arm and just before it dropped free, it got caught up on the rim of the pushrod cup. That would mean of course that the rocker arm would open the valve further than intended. Which would also introduce the valve and the piston in a rather unpleasant collision, thus bending the valve stem.
I’m starting to think this was a sign that I should drop a 1776 or even larger engine in the car.
Stay tuned.
