Home › Forums › MGTD Kit Cars › VW Based Kits › Master Cylinder ^68 VW
- This topic has 7 replies, 6 voices, and was last updated 15 years, 7 months ago by
chuck schmit.
August 6, 2010 at 4:56 pm #233071
Just bought 53 mgtd kit with 68 model vw engine Replaced Master Cylinder but cant get it to pump up..any one have any ideas?
Gary
August 6, 2010 at 6:13 pm #241879Gary,
I had the same problem w/ mine when I replaced. Two things – Could be
a bad unit as many overseas units are very poor – also did you put brake
fluid in the MC before you installed? Many times if you don’t it is a bear
to get the air out and get some pedal pressure.
Lastly – after spending a huge amount of time tying to get the system up I
found a big help through a friend. Get a cheap garden sprayer and drill a
hole in the top of a 1 quart oil can lid and plumb the garden sprayer hose
through the lid w/ a fitting from H/D or the like and it will screw on the
top of your Brake fluid tank – you can then pump your system up w/
about 5 pumps or so and start bleeding from the rear to the front. The
pressure will force the fluid through the bleeder nipples real fast. If the
pressure goes down you can give the garden sprayer a couple more
pumps till your done. Then adjust the brakes all around.
Good luck and let me know if I can help.
Dale
August 6, 2010 at 6:15 pm #241880Gary,
PS
Sometimes you need to replace the rubber hoses as they collapse inside and
you can not tell from the outside.
August 6, 2010 at 6:32 pm #241881Gary, Try loosening the brake lines where they connect to the master cylinder while having a helper press down the brake pedal. By doing this you will be bleeding just the MC ,not the entire system. Once you get fluid flowing to the lines you can then bleed the wheel cylinders .
I agree with Dale about the rubber hoses. Mine would let fluid go to the wheel cylinders but would not let it retuun when the pedal was released thus keeping the brakes slightly applied.
August 8, 2010 at 10:04 am #241882Agreeing with what was already posted, if the master cylinder is not “bench bled” first you could run into this problem. The collapsed hoses will also cause the problem.
Keep in mind that when most of these cars were built, the donor cars were lucky to get a decent clean up, let alone any new parts!
A couple VW based tips: 1)When buying replacement parts, if the GERMAN made part is available, spend the extra few $$ and buy them. 2) If it says made in China, don’t use it. #2 being true for any make car, new or old!
Pink MG40398.4221064815
August 8, 2010 at 9:06 pm #241883Thanks to all as lasrry lthe cable guy says” got er done” will be posting pics of my new project in the near future
August 9, 2010 at 10:54 am #241884Good on ya, Gary!
August 23, 2010 at 5:08 pm #241885I replaced my 74 dual master cyl this w/e because it leaked down under pressure, like when you have to stop real fast! I bled it really good on the bench then plugged all the holes and just pulled one plug at a time and put in each line one at a time. I didn’t even have to bleed the system when i got it all hooked up. This is a measy job, however. I had to clean my driveway when I was finished.
The brakes work good now and I can actually lock up the rear wheels now.
Thanks for the tip on bench bleeding!
Chuck
