Home › Forums › General Discussion › Parts interchangeability ?
- This topic has 6 replies, 5 voices, and was last updated 3 years ago by
Toller.
December 25, 2022 at 9:21 am #308328
Are the cockpit dimensions the same between the VW models and the Pinto models of the Fiber Fab TD kits ? Specifically will the soft goods interchange ? Top, tonneau, carpets, seat covers etc ? TIA
December 26, 2022 at 8:12 am #308329With the exception of carpeting, yes. I drive a FordTD and had come across someone selling the soft trim package for a TDr cheap. (Builders garage had burnt down and these items were in his basement) Seat covers and tonneau fit fine. I did not receive a top so I can’t confirm. Carpeting for the back area behind the seat fit but the floor is radically different.
"Drive Happy"December 26, 2022 at 10:03 am #308330Thanks 🙂 I’m in a similar situation . Found a guy who bought an unbuilt Ford kit years ago and has decided to part it out . I’m rebuilding a VW car and need all the soft goods but wasn’t sure if his stuff would fit. We are on opposite sides of the country so I can’t test fit any of it. Great info, thanks again 🙂
December 26, 2022 at 8:17 pm #308331Caveat: this interchangeability is between Ford and VW of the same brand kit. So Fiberfab to Fiberfab, Dutchess to Dutchess and Allison to Allison. If you have a MiGi VW and buy a British Coach Works or other brand dashboard it won’t fit.
December 27, 2022 at 9:42 am #308332If you haven’t moved on this, would you post a link? I would like to see what he would take for the carpet set.
"Drive Happy"March 13, 2023 at 10:45 am #308443Can anyone tell me where I can get either a carpet kit or side door panel/trim kit that would fit a British Coach Works MG TD body?
March 16, 2023 at 11:53 am #308446MgMagic does carry a carpet kit but in description it is designed for Classic and Fibrefab. I went to local marina that did custom carpet and vinyl work for boats to get them to make door panels and carpet for MiGi
David B Dixon
Sabine -
