Problems with top
Home › Forums › General Discussion › Problems with top
  • #232299
    patti
    @patti
    Hi all
    Recently purchased a garage-kept ’52. Top never put up. Snaps on side of windshield fine. Can’t figure out how to get it on top of windshield. Please advise.
    Thanks,
    Patti
    #237096
    Depends on the manufacturer.
    On Classic Roadsters tops, there is a sleeve about an inch wide sewn across the full width of the top. They provided (in early years) an aluminum bar, (in later years) a flexible plastic bar that slid into the top sleeve. Once in the sleeve, the roof folded over the top of the frame and the bar was inserted in to the slot on the leading edge of the windshield frame.
    Other manufacatuers had  series of snaps all along the front of the roof. The roof came over the top of the windwhield frame and attached to snaps screwed into the underside of the frame’s leading edge.
  • The topic ‘Problems with top’ is closed to new replies.
