Home › Forums › MGTD Kit Cars › VW Based Kits › Spare tire musings….
- This topic has 13 replies, 10 voices, and was last updated 12 years, 3 months ago by
Hubert Atkinson.
December 24, 2013 at 12:57 pm #235025
Obviously with the “fake” spare tire and luggage holder, the rear hatch is not meant to carry any weight of much amount. Wondering if anybody has “reinforced” the lid enough to carry a real spare tire….
December 24, 2013 at 2:15 pm #259195It all depended on the manufacturer’s design.
Classic Roadster Ltd.’s Duchess used steel “z-bars” as the engine cover hinge and a support for an external spare tire.Inteh pic below, you can see the black bar running behind the spare. Under the spare is a steel structure that extends through a hole in the engine cover, bends behind the fiberglass, and is bolted to the z-bar.The parts and assembly are shown in Classic Roadsters Ltd. assembly manual, beginning on page 80, which is the next to last page of Part 4 – Body and Interior (pages 57 to 81). (You’ll find it at the end of the Download Manuals page.PMOSSBERG2013-12-24 14:16:02
December 24, 2013 at 5:22 pm #259196Mine is a CMC Ford powered with the spare and luggage rack on the back. It is a real spare and I carry all sort of things on the rack, lawn chairs (bag type, coolers even a suit case if we go over night. I looked under it and there is not much reinforcing it, just a steel bar about a foot long with the studs for the spare.
December 25, 2013 at 5:25 pm #259197My Lafer is VW-powered so the spare is stowed up front. I’ve owned it since February 2007, and in all that time have never been stranded with a flat. Wondering lately if I might jettison the spare altogether and use the space for a small tool kit and a couple cans of Fix-A-Flat instead. Thoughts?
1981 Lafer TI
1600 cc Type 1 engineDecember 25, 2013 at 10:52 pm #259198My Chrysler Crossfire had no spare from the factory. It came with a can of Fix-a-flat and a small compressor. No spare is not too unusual now.
December 26, 2013 at 8:03 am #259199Pro spare here, Hugh. My car came with the proper setup and for that I am grateful.
If I were to mod one up from scratch I would copy Paul’s Classic Roadsters Duchess. It’s simple and effective and it looks more TDesque than most alternatives (mine included). Conduit pipe or, if handy, the steel from an old swing set would work.
December 26, 2013 at 9:32 am #259200My TD has the insert in the engine cover for the spare tire. It bolts to the engine cover with 8 bolts washers and nuts and then has a two lug nut bracket bolted to that to hold the actual spare. I intend to keep that setup and if I run into a problem, get an original TD spare tire rack off the ebay.
"If one thing matters, everything matters" - from the book The ShackDecember 26, 2013 at 10:34 am #259201Allen,
Be careful…that original TD spare tire rack may not fit over your fiberglass “tank.”To paraphrase the traditional carpentry advice…measure twice…buy once.Paul Mossberg
December 26, 2013 at 10:45 am #259202That’s always good advice Paul. At the moment I’m pretty certain the insert in the engine cover for the spare tire will securely hold the spare.
"If one thing matters, everything matters" - from the book The ShackDecember 26, 2013 at 10:59 am #259203On a related side note — I talked to MG Magic about theirs, since my early FF has the fake spare also. The guy said that theirs (MG Magic’s) for the VW might not cover the hole in the engine lid, but that the one for the Ford/Chevy kits would. That’s the one that he recommended to use…
I’ve yet to buy or try either one — still mulling the options and may go for the compressor/Fix-a-Flat solution.Early FF TDr on 69 VW pan
Slowly coming back from the ashes...December 26, 2013 at 11:30 am #259204When I first got my Daytona MIGI, I made a list of things that I wanted to do to it. Putting a spare on the rear was in the top 5. I now have real knock off wire wheels and a spare wire but, on my car, you simply can not take off the “fake” spare continental kit and mount a tire. The carb and it’s air cleaner are way too far into the inside of the continental. I mention this to warn you that this is not always obvious. I had removed my fake and had a spare mounting kit available to test. Can’t be done without Major fiberglass work or perhaps repositioning the tub by moving it aft.
However, if your intention is just to carry a spare, perhaps what I did will work for you. A full sized spare tire didn’t fit up front. I could not find a new super small tire to mount on my 5th wire so I called every used tire sales place east of Raleigh NC and finally found one. (My wires are 14″) It fits nicely up front and I’m happy.When my friend Happy Jack bought his TDr (Fiberfab) he wanted to carry a spare. I showed him what I had done, and he ended up buying a super small tire for his stock VW 15″ wheel and it also fits nicely up front.December 26, 2013 at 4:26 pm #259205Or – you can go dual carbs and then your spare will not have the carb and air cleaner up inside the spare. More then one way to skin a cat. Many options – your choice.
December 26, 2013 at 4:36 pm #259206The Duchess’ configuration left plenty of room for a single carb/air cleaner.
December 27, 2013 at 7:59 pm #259207Well on mine, the “spare tire cover” is a separate piece. Appears to be pop-riveted on. And the clearance is needed for the air cleaner/carb…. Might be able to rig something on the “luggage rack”. But I’d still worry about the weight. Maybe the best solution is like the Solstice-a can of fix-a-flat….
