Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › Windshield
- This topic has 18 replies, 7 voices, and was last updated 10 years, 2 months ago by
January 19, 2016 at 8:23 pm #236007
Saw somewhere a DIY on how to install stock TD windshield on a Fiberfab? Does anyone know the link?
langan 2016-01-19 20:38:58 January 19, 2016 at 10:27 pm #267074Hey Langan, I looked up on google for a Windsheild/Glass company, and they cut me a new flat autoglass windshield. They installed it in my orginal Dutchess TDr frame, all for about $150. Just a thought. I also purchased on line from a Dune Buggy web site, new rubber gaskets and the frame to car car molding. I do not remember the cost for the new rubber, but not that expensive.
Dave
Dave
Lakeland, Florida, where we drive Topless every dayJanuary 19, 2016 at 10:34 pm #267075Thanks but I ment where the guy reworked the fiberglass on cowl so original mg td posts would fit. The Fiberfab is square and TD is round he shows how to cut fiberglass and reglass to fitlangan2016-01-19 22:41:57
January 20, 2016 at 8:05 am #267076You just cut off the squared-off part and clean behind it, then stick some aluminum tape on the back side and glass over the holes you made from the outside. Peel the tape off after the first layer or two and glass the back (or just leave the tape there and glass out past it an inch or so), then glass the outside again and shape it with 80-grit. When you’re close to the right shape, use Bondo or similar to get closer, and then spot putty for the pinholes and small imperfections. Prime and paint.
If you’re ambitious (or paranoid), cut you a piece of 16 or 18-gauge steel sheet, 4 x 6 inches or so, shape it to the curve of the inside of the scuttle where the posts will go, and glass that in to reinforce the area.This whole operation will take you about 3x as long as you expect. If you’re done sooner it means it’s not good ehough yet. Body workers use a bit of rattle-can glossy paint to check their work as they go for smoothness, flatness, etc. Hit it with some paint and look at it in daylight, and with light from many angles, and keep working it until it’s a nice smooth curve that blends in seamlessly. BUT:Do not start this project before you have a complete and useable TD windshield kit. And measure it all 30 times first to make sure it will fit.edsnova2016-01-20 08:08:36
January 20, 2016 at 9:29 am #267077Thank you very much
January 20, 2016 at 9:56 am #267078Thanks Ed! You beat me to the punch.
Langan…the most critical sentences in Ed’s post are the last two.
The cowl on your TDr may not be the same width as the cowl on an original TD. If it’s not, the job will entail far more than just rounding off the corners to match the curve on the frame.Ed said don’t start the project until you have a complete TD frame.I would say don’t even invest in a TD frame until you know have double and triple checked the measurements and know it will fit.PMOSSBERG2016-01-20 09:58:44
January 20, 2016 at 10:04 am #267079I am hoping it is the same I just bought complete windshield for 500 and still needs about 200 from Moss. So worst case I ajust windshield frame if shorter rubber seal ok if longer I buy two.
In the article I am looking for described same method of glass work I was hoping it told what kit. I won’t be home for two more weeks so just building in my head. ThanksJanuary 21, 2016 at 9:38 am #267080Langan, will try to find the thread.
But it probably won’t matter what kit the owner was working on. Just about all replica TD cowls have the squared off corners. As Ed said, hack ’em off and apply new ‘glass to match the correct profile.
January 21, 2016 at 8:36 pm #267081Some previous discussion on the subject, with measurements.
It was my impression (and I can’t remember how I learned this, but I am pretty sure) that the BCW windscreen is slightly narrower than the original TD.Here’s a link to a measurement of just the glass from a TD. Looks like 41 inches. So mine would appear to be closer to “stock” than I recalled.edsnova 2016-01-21 20:39:14 January 22, 2016 at 11:21 am #267082I can’t believe I didn’t think about this until now. But there is another major issue to consider if you want to switch to an original TD windshield frame.
Your TDr roof and side curtains will not work with an original frame. And I’m not sure if they can be made to work.
Not trying to dampen your enthusiasm. I just want you to go into this as well informed as possible.
January 22, 2016 at 11:53 am #267083Thanks…thinking I also want to do Original type roof may be custom. If project come out well it will be worth it.
January 22, 2016 at 7:22 pm #267084The original top stays are pretty simple and Moss sells them (90a–$6). You just embed the sockets in a piece of hardwood, 2 x 5/4 or so, and wrap that in the canvas. You then just need two thumb screws to hold the front bow to the windshield pins.
To use the zip-in side curtains just have your top maker put the zipper along the sides of the top. I’d recommend this even if you want to mess with the original style side curtain frames. Those are mostly flat stock. No point in paying $1,000+ to Moss for them, since they won’t fit anyway. I’d guess six 6-foot bars of this would probably be enough to make four TD side curtain frames. $24, plus shipping–so call it $35.January 22, 2016 at 7:43 pm #267085Great info thanks
January 23, 2016 at 12:28 pm #267086Hey Ed,
That link to http://WWW.ONLINEMETALS.COM is a GREAT reference for anyone needing metal to build/patch/fix stuff — but a lot of people may not click on it in the post so I thought I’d highlight it for folk’s future reference….January 23, 2016 at 1:52 pm #267087Thanks, Jack. I have ordered from them a couple times. I suspect it’s cheaper if you can pick up stuff locally, and way cheaper to go pick stuff from a scrapper or metal recycling outfit, but you can’t beat the convenience.
January 23, 2016 at 5:28 pm #267088Anonymous
InactiveAnother thing to consider going to a real MG windshield frame is the VW wipers are cowl mounted. MG wipers are mounted on windshield frame. Folding wind shield is nice but VW wipers get in way of folding windshield.
January 23, 2016 at 5:52 pm #267089True that the cowl mounted VW wipers look like they could interfere, but mine are comfortable under the windshield when folded. No problem. (Daytona MIGI with brackets that I modified.)
January 23, 2016 at 6:05 pm #267090Yeah, the folding windshield works fine with cowl-mounted wipers. The TF had that setup.
January 26, 2016 at 6:18 pm #267091I did not find an entire thread.
But dougsgarage posted a couple pictures of his cowl modifications in these threads:Here are the pictures he posted:
PMOSSBERG 2016-01-26 18:19:29 Paul Mossberg
