Home › Forums › MGTD Kit Cars › Chevy/Ford Kits › removable hood sides
- This topic has 17 replies, 7 voices, and was last updated 11 years, 6 months ago by
ricrx7.
October 22, 2014 at 12:05 am #235440
Anyone done a 4 pc. hood like a real TD? I was looking at instructions and front fenders bolt to hood sides. I assume some panels need to atach to frame and provide a place for hood to close against. I need to look at real TD I guess?
October 26, 2014 at 10:54 am #261829Haven’t done it yet. But have been wanting too. Waiting for the bucks. I think it will be an expensive conversion, also don’t want the car to be disabled for a lengthy time span. I would like to gather the parts up and do most of the work before disassembly. Hopefully just trading the parts off and on the car. I know it won’t be that easy, nothing is.
October 26, 2014 at 12:55 pm #261830I plan to make removable sides and hood from either crs or aluminum but not until next summer
tommietd build
October 28, 2014 at 10:12 pm #261831What do your front fender bolt to now? I have not started my build. Just dreaming
October 29, 2014 at 10:58 am #261832I’m building a front engine TDr. I added brackets and a length of tubing at the edge of the fender.
I’ll post photos later.
October 29, 2014 at 1:19 pm #261833I considered that when I had mine apart last year. Just run a strip of angle from the cowl to the radiator shell for the hood to hinge and latch on. The fenders, having the mounting flange, would be plenty strong without the side panel.
"Drive Happy"October 30, 2014 at 5:06 am #261834Oh just tilt the front end……
November 2, 2014 at 1:41 pm #261835a couple photos showing fender mounting and hood support
November 2, 2014 at 1:43 pm #261836another photo
November 2, 2014 at 1:59 pm #261837Melvin, what transmission are you using and what did you use for the hydraulic clutch?
"Drive Happy"November 2, 2014 at 2:27 pm #261838Bill,
The transmission is a Mustang 4 speed, still looking for a 5 speed but not that important now since I have so many other things to do. The clutch master and pedal assy is from Speedway also the pull slave. I think they are rebranded Wilwood, very similar. The brake masters and pedals are Wilwood. Neat setup, there is a balance bar between the masters to adjust the bias. The rear is 7/8 , the front is 3/4. I wanted to use a cable clutch with a quadrant, but the whole thing was too busy. I tried to fit a single brake master but ran out of space. I am happy with the setup now, except of course the cost.
February 20, 2015 at 12:28 pm #261839What engine is in the car and what replica manufacture did the car start out as? Thanks.
Chevy 2.8 V6, 5 speedFebruary 20, 2015 at 1:30 pm #261840The body is a Fiberfab from 1982, VW based but built with a Ford 2.3.
February 25, 2015 at 9:41 pm #261841I’m interested in converting my BCW Chevette to an original hood. Does anyone know if an original TD folding hood will fit the cowl and radiator?
Chevy 2.8 V6, 5 speedFebruary 25, 2015 at 11:16 pm #261842Why not re-work the original side pieces? They’re already fit, yes?
February 25, 2015 at 11:22 pm #261843Yes and they would still be fiberglass. So just a matter of getting two piano hinges and cutting the hood at the lower edge? Then fabricate attachments for lower hood latches? So have many people done this?
Chevy 2.8 V6, 5 speedFebruary 26, 2015 at 8:19 am #261844Never heard of it. I think you have a remote latch on each side? If so, you’d be cutting the “shelf” on each side piece. You would disassemble them from the frame parts. You would fab a new latch system for the bottoms. You would probably add some small strut bars to replace the strength they gave the nose structure.
Then piano hinges and fiddling.
March 28, 2015 at 5:28 pm #261845Thanks. Good ideas. I’m thinking I might be able to remove the side panels, add spacers to the attachment bolts and then slot the side panels at the lower old attachment points so they would just push back down where they were. Then use some quick release fasteners at the front and rear edges.
Chevy 2.8 V6, 5 speed -
